Dec 17 2005, 11:35 PM
Post
#1
![]() Canada's Leader in Performance Product Availability ![]() ![]() ![]() Group: Admin Posts: 7933 Joined: 17-June 03 Member No.: 1 |
RADAR RUNS Q&A Thread
With Special host Chris Hanson ( "Billetman" ) - driver of 190+mph MODZILLA! With excitement brewing We're thrilled to have Chris offering his time to us this season, so Fire away your questions! http://www.andersonchassis.com/Video/Modzilla175_384.WMV Thank you Chris Imagine pull'n this chunk down off the trailer, turn'n to the Bro's and say'n "Say El-o, ta ma Lil Fren"
Dec 17 2005, 11:48 PM
Post
#2
First question for Chris:
Who's the hot blonde on that bad rocket?
Dec 18 2005, 05:00 PM
Post
#3
Radarruns.com 190+ club Sole member! ![]() ![]() Group: Members Posts: 10 Joined: 13-November 05 Member No.: 949 |
That would be Nikki, the Wife of the guy I'm shaking hands with.
And you all thought he was congratulating me. -------------------- "It don't cost nothing to go Slow!"
Dec 18 2005, 05:43 PM
Post
#4
![]() ADVANCED DYNO ![]() ![]() ![]() Group: Members Posts: 482 Joined: 2-October 03 Member No.: 50 |
So what gear ratio you running in that bad boy?
about 1.25-1? And about what hp does it have ,give or take LOL -------------------- Advanced Dyno
(613) 925-5483 |
Dec 19 2005, 06:45 PM
Post
#5
Another for you if you where to say , have a stock clutched sled and geared it say 1.50-1 what chages would you have to make to the setup to make it work.
Thanks in advance. -------------------- Advanced Dyno
(613) 925-5483 |
Dec 19 2005, 09:35 PM
Post
#6
![]() Frozen Thunder 120+mph site member ![]() ![]() ![]() Group: Members Posts: 138 Joined: 28-February 05 Member No.: 684 |
my intrest is in 131 miles per hour with a 809 mach z using stock pipes. I have sc10 with big wheel and a .5 in profile track,144 studs.any tips for me? Thanks.
MACH ZZZZ -------------------- "I'm not old enough yet to go that slow"
Dec 20 2005, 04:57 PM
Post
#7
QUOTE (Machzzzz @ Dec 19 2005, 09:35 PM) my intrest is in 131 miles per hour with a 809 mach z using stock pipes. I have sc10 with big wheel and a .5 in profile track,144 studs.any tips for me? Thanks. MACH ZZZZ adrenalator8, I would gear it taller than you are 1.5 to 1, say around 1.75 to 1. But it is tough to say without operating rpm, horsepower or desired mph. (MPH needs to be realistic for the horsepower you have to work with.) And Modzilla is geared closer to 1 to 1. How close is a trade secret. Machzzzz If you want to go that fast use the gearing chart and gear for 10 or so MPH less at 1 to 1, then let the overdrive do the rest. But, I think you'll need more power to get to 130 unless you have an Infinite distance to run. -------------------- "It don't cost nothing to go Slow!"
Dec 20 2005, 05:22 PM
Post
#8
Chris - here's a question for ya.
Contrary to what most think for running top end numbers, is it really better to be studded heavier ? Here's what I'm saying, on our 03 project sled, which is running the 128" by 13" track, most would say, or have advised 1 to 2 Woody's drag eliminators per bar which would give us 52 or 104 studs, yet we ran 124mph last season with 170 studs the size of your forearm :P We have recently heard from one of our secret advisers ( - this is a questions I'm sure I few could gain some advice from because any of the sleds I see running at the lake , even with speed tracks, are only running about 105 pics at the most thinking less rotational mass is the ticket? Thanks |
Dec 20 2005, 05:40 PM
Post
#9
Alittle more info for you
05 mach -z with about 172hp-3000' run looking for about 130mph Sled has run 125.9 with 1.69-1 gearing w96 studs and there wasen't much left on the primary also c+c is dead on. I was thinking that I should keep the primary in about 1.5-1 ratio and let the torque work for me. I doesn't cost much to give it a try if doesn't work I'm only out 150bucks -------------------- Advanced Dyno
(613) 925-5483 |
Dec 20 2005, 05:48 PM
Post
#10
172hp ? cryps..... I should get a nitrous 'handicap' for even attempting racing that thing.... wait a minute " I WON " :P
Dec 20 2005, 05:58 PM
Post
#11
OH YOUR A FUNNY ONE , LOL
(613) 925-5483 |
Dec 21 2005, 04:56 PM
Post
#12
Spenc,
That's a tough one to answer. True the air under the sled affects traction, but on the otherhand more studs means more horsepower being used to pull those studs out of the ice. My personal preference would be just enough traction to keep the track from spinning on the big end. This is easy enough to see. When you make a run down a virgin piece of ice look out near the end for the stud marks in the ice. They'll be hard to see but their there. If you just see pick mark you're not spinning the track, if you see some scratch marks more than likely the track is loosing traction with the ice surface. One other factor to consider is the surface you're running on too. If the ice is white it isn't very good for traction. You need to find the black hard ice to make the most of this test. And as always sharpen, sharpen and sharpen again the studs. adrenalator8, You might be at the maximium MPH for the horsepower you have. You need to consider the frontal area, or hole that your sled is making in the wind at speed. That takes horsepower to make that hole and factoring that in there may not be any left to accelerate the sled, no matter how far you run. But it can't hurt to try. Nice thing about changes is only 3 things will happen. You'll go Faster, Slower or Stay the same. I think I'd try to stick alittle closer to you current ratio. Going to 1:50 to 1 is about a 15mph change and I don't thnk you'll see the benifit of the extra gear. Try 1 tooth smaller on the bottom or 1 tooth bigger on the top. -------------------- "It don't cost nothing to go Slow!"
Dec 21 2005, 06:17 PM
Post
#13
Thanks for the quick reply,tryed it tonight in the 1500' test field
Pulled about 105mph but it's snow covered same conditions with the stock gearing was 110mph. Have to get on some ice to tell. -------------------- Advanced Dyno
(613) 925-5483 |
Dec 21 2005, 06:56 PM
Post
#14
Wouldn't it be funny'r than shyt if we all did all this work, spent all this time and $$$ and none of us tops our times from last year? LOL! That's what APEX AL has been warning.. but I can't see it...not going to a speedtrack, etc etc.
Dec 21 2005, 08:35 PM
Post
#15
I just wanted to be clear. I don't care how much I need to spend or how bad I must CHEAT, I will go faster than last year. The only thing better then 122mph is 123mph. We can pass that on to our good friend Al :rofl Oh and a special thanks to Chris for his responce -------------------- "I'm not old enough yet to go that slow"
Dec 21 2005, 10:24 PM
Post
#16
Not to worry "Super DAVE", we all know 'YOU' are going over 122mph. That nitrous kit you are having us hold for you ( on the "DOWN LOW" ) will surely send that Precambrian wheel barrel with ski's over 130mph whether "IT" likes it or not !
Dec 22 2005, 03:06 PM
Post
#17
![]() Regional Site Trail Reporter ![]() ![]() ![]() Group: Members Posts: 51 Joined: 2-December 04 Member No.: 515 |
Good for you Dave!!
1 thing, that I like about someone, is when they call it the way it is! In my book that is what you are doing, I will even help! -------------------- FIRST !!! Or wrench it, til no one can catch it ! |
Dec 22 2005, 08:11 PM
Post
#18
Thanks APEX AL for the offer to help.I'll take you up on any help you offer.
Off subject,,,,, George Greiken, Dave Sutton and Myself were at the lake today trying to figure out a way that we can get on with the sleds. The slush ice is not quite frozen in the centre yet. It's a long wait for ice but it wont be long now -------------------- "I'm not old enough yet to go that slow"
Dec 22 2005, 09:24 PM
Post
#19
Where "is" Dave Sutton? Get him on here!!! we need another 'competitive' voice
Dec 23 2005, 01:54 PM
Post
#20
"Hmmm..... ok, well.... as far as studding then we'll drill out for 170 but only put 52 in? on our 128" track that's 1 per bar or 2 every second bar... which would you recommend. Or would you go 2 per bar for the entire track for 104 studs."
I forgot to mention that it will also depend on how much longer the stud is vs. the track lug height. 3/4" above the track lug is the Length that is standard for racing. I'm also reffering to steel picks not trail studs. I spoke to a friend that races F7's and he recommended that you start at 3 per bar. You can always add or subtract after the initial testing. If your going to drag race you'll need 50%-60% more than if your goal is absolute speed. -------------------- "It don't cost nothing to go Slow!"
Dec 23 2005, 04:31 PM
Post
#21
Thanks Chris
After hearing that advice and advice from Al Doberstein ( F7 'guru' ) who said put 170 drag eliminators back in it, we'll do just that. We'll play the stick the track to the ground at high speed to avoid clutch spin game... That's most likely why our clutches stayed 'kool' last winter. It appears this things heading for 1000' ice drags at 'The STRIP' so we'll take a shot at beating 124mph this season, but we'll be ready to HOOK UP so to speak in case anyone wants to try us on for size [size=2]Your advice is appreciated Chris , so again thanks |
Jan 1 2006, 02:53 AM
Post
#22
Advanced Member ![]() ![]() ![]() Group: Members Posts: 72 Joined: 28-December 05 Member No.: 1001 |
Thats a 670 rotary no????
-------------------- 04 RX-1 Warrior
99 Acura 1.6EL 300WHP 02 Grand Vitra little 30" BFG's |
| Guest_madcow_* |
Jan 17 2006, 07:32 PM
Post
#23
Guests |
I know you dont know me chris but i spoke with you at rush city last year, so i say this as a joke,
what about rick schellbach getting his arm fixed and then getting NOS to give you a run for the money. he is a crafty man. you never know what he can come up with. heck, i bet he tried to get his sled in improved stock at least once in his life. lol |
Jan 18 2006, 09:04 AM
Post
#24
![]() mrpolaris18 ![]() ![]() ![]() Group: Members Posts: 459 Joined: 16-January 04 From: Trenton. Ontario Member No.: 206 |
Well I'll be it's Madcow. Is that you Jon from Minnesota? Welcome to the forum
-------------------- Don't take your organs to Heaven,
Heaven knows we need them here |
| Guest_madcow_* |
Jan 18 2006, 08:35 PM
Post
#25
Guests |
yep its me. i took your advise and wound up here.
chris is right on the studs thing. for stock 800 i was only going to run 96 picks this year, you can put your engagement on stock sleds real low. that gives your clutches more time to shift out and reduces spin on the line. |
Jan 19 2006, 10:53 PM
Post
#26
"...what about rick schellbach getting his arm fixed and then getting NOS to give you a run for the money. he is a crafty man. you never know what he can come up with. heck, i bet he tried to get his sled in improved stock at least once in his life. lol"
I'll give Rick credit He never gives up and is willing to try anything -------------------- "It don't cost nothing to go Slow!"
Jan 23 2006, 02:33 AM
Post
#27
Newbie ![]() Group: Members Posts: 3 Joined: 23-January 06 Member No.: 1058 |
Hello Everyone, I Found this Site while Browsing Looking for Mods for my Sled...I Figured I'd post the Video I took of MODZILLA Going 192.2 M.P.H. I cant wait until March to see If anyone can Top this Record Wow... And I heard its in the New Guinness Book.. Congrats on that!! The video is a little shaky lol... you would be shaking to If you were there hehe.... Here is the Link...
My MODZILLA Video |
Jan 27 2006, 11:49 PM
Post
#28
Hi Modzilla
I have now acheaved my 131.8mph and find myself looking toward 140mph. In your opinion,what kind of track would you recommend for safty and speed. I have a new KIMPEX speedster track at the shop but am thinking that its not what I really want on the sled.Thanks for your thoughts. Dave -------------------- "I'm not old enough yet to go that slow"
| Guest_madcow_* |
Jan 29 2006, 05:59 PM
Post
#29
Guests |
depends on the rules of the race. around here a speed track would put you in the improved stock class or higher, but a flat track would automatically put you into superstock. a speed track should be fine. but if you can run the flat track you will gain some mph just in the track swap.
some people run a cleated track. witch in "old days" of racing was just fine, but some bodys dont allow that anymore. |
Feb 4 2006, 01:12 PM
Post
#30
Chris... How tight is DANGEROUS for gear/chain ratio's? Got one we'd love to try but the chains and sprocket/gears had to be tapped on it was so close.... is it ok to take a few easy test runs up and down the ice before GET 'N INTO ER , or would you just not bother for fear of it coming un-glued? The chain is tight... no tensioner needed at all... gearings perfect as far as ratio's but......
thanks |
| Lo-Fi Version | Time is now: 6th September 2010 - 07:12 AM |
