Misc Parts - CLEANING UP, MUST SELL
3 replies to this topic
#1 Mavrick
    BAM
  • 57 posts
Posted 21 November 2004 - 01:20 PM
Making space in the garage.. must get rid of this stuff!
1) 73mm brake upgrade.. includes rotors, bearings, pads, calipers w/hardware, flex lines w/banjo bolts, spindles reemed 5/8" for bumpsteer kit... with freshly turned drums and new drum brake hardware.. Note that ALL parts listed are brand new (except flex lines/drums), have only been installed on the car and removed. Car never touched the ground. Bearings etc. been cleaned of grease. $225 firm - Sale pending, PM if interested!!
2) Stock front calipers, brackets, flex lines w/banjo bolts, and hardware from a 94GT
3) Stock springs from 89, rears untouched, fronts have 1 coil cut off by previous owner
4) Struts from a 99GT with less than 20k on them
5) Brand new poly urethane "strut mount bushings?" PM for pics, they are brand new. I assume for 79-93 but i'm not sure.
6) 4 10 Holes with good rubber. 205/65/15 on two, and stock 225's on two. With center caps. $120
7) Fan shroud from 89
8) Stock shifter knob
9) 220km/h speedo
10) Spare tire, space saver aluminum type from 1990. Someone wanted it but hasn't showed up for it??
Other misc stuff in the pic below.. dimmer switch, ashtray, grey seatbelt receiver, speaker grills, interior door handle bezel, window rollers, grey 3rd brake light for coupe, automatic shifter bezel, gauge shroud with LX light switches.. stock strut plates from 89.. freebie
73mm Brakes..
#2 Mavrick
    BAM
  • 57 posts
Posted 05 January 2005 - 11:37 PM
To The Top!
#3 trev
    Newbie
  • 9 posts
Posted 24 April 2005 - 09:04 AM
hello l am interested in buying the brakes you have forsale,if you still have them.
trevor timpson
timpson88@hotmail.com
#4 Mavrick
    BAM
  • 57 posts
Posted 12 June 2005 - 08:39 PM
The brakes were sold long ago.. but the guy i sold them to, is selling all the same parts again (never used still).
Check out this link..
http://www.gtamc.com/forums/showthread.php...&highlight=73mm
Reply to this topic
