Jump to content
BoonDocKer Liquid Nitrous Systems
3 replies to this topic
#1 Guest_Spenc_*
  • Guests
Posted 12 December 2005 - 02:10 PM
BoonDocKer LIQUID NITROUS SYSTEMS
As part of our new ' VENOM PIT ' wholesale Nitrous Supply, we've added the BoonDocKer lineup to our endless available manufacturers products list.
http://2koolperformance.ca/forum/index.php?showtopic=1571
  • Attached Image: post-27-1135287632.gif
#2 Guest_Spenc_*
  • Guests
Posted 12 December 2005 - 03:24 PM
example Kit #1 - EFI system
BoonDocker nitrous kit for Snowmobiles with the BoonDocker EFI Control Box. Complete with everything you need. Priced & Shown here with aluminum 3lb bottle
$1435.00 CAD complete. Add $239 for 2.9lb Carbon Fibre bottle or add $349 for 4lb carbon fibre bottle.
As always, we will not be undersold on any performance products, so if you find this product anywhere cheaper in Canada, let us know and we'll beat THAT price! :P
sales@2koolperformance.ca
1 613 925 4015 or 1 613 349 6459
*Local Nitrous refill station open in Prescott, Ont. 613 925 4223 Ask for Tony when you call and tell him you were referred from 2KOOL PERFORMANCE . All our clients will receive $8.49 per lb pricing.
  • Attached Image: post-27-1134419057.jpg
#3 Guest_Spenc_*
  • Guests
Posted 12 December 2005 - 04:19 PM
BoonDocKer EFI Control Box $480 cad
We'll be providing the D&D Programmed BOONDOCKER Boxes for the 2006-2007 season! email for details
FEATURES:
- LCD screen with 5 botton interface
* allows user to program Control Box without a laptop or PDA
* Screen can be seen in direct sunlight
- A wiring harness will be provided that plugs into existing brand-specific connectors on the sled
* no wirecutting or splicing
- The Control Box will be able to unplug from its wiring harness.
* External 9 volt battery can be used to run the box off the sled to gain familiarity with the Box or when the engine is off to make adjustments
FUEL TUNING CAPABILITIES:
- Control Box modifies existing fuel map
* user does not have to creat a new fuel map from scratch
- Fuel can be added as well as subtracted
* Extra performance can be gained on stock sleds with factory mapping that is too rich
* allows mods that require more fuel like pipes, heads, porting, big bore kits, etc
NITROUS CAPABILITIES:
- Monitors and displays nitrous pressure
- Nitrous pressure sensor supplied in BoonDocKer EFI nitrous kit
* Fuel delivery automatically adjusts according to nitrous pressure
- Uses separate wiring harness for nitrous control
* a BoonDocKer Nitrous System can be added later with the same Control Box
- Fuel for nitrous is controlled by Control Box
* fuel adjustments can be fine-tuned
* Nitrous is still adjusted by changing nozzles in nitrous manifold
- Nitrous solenoid is driven b Control Box
* fuel and nitrous delivery are controlled by the box - if one system fails, the other will be shut off
  • Attached Image: post-27-1134422367.jpg
#4 Guest_Spenc_*
  • Guests
Posted 19 December 2005 - 05:23 PM
example Kit #2 - CARB'D system for 3 cylinder application ie - MACH Z
Complete with everything you need. Priced with aluminum 3lb bottle
$1074.00 CAD Add $239 for 2.9lb Carbon Fibre bottle or add $349 for 4lb carbon fibre bottle.
