Jun 3 2009, 03:42 PM
Post
#1
anti stock!! ![]() Group: Members Posts: 2 Joined: 1-June 09 From: Saint John N.B. Member No.: 41940 |
sup every one, I just picked up a 1987 stang lx. I heard about the site and figured i would check it out.I see there is a fellow Saint Johner on here, We should get together some time for a coffee
She started life as a 2.3 but how things have changed, here are the jist of the mods 750 Holley -RPM Air Gap Intake -Trick Flow Heads w/ Valve and Port Work -fms 1.72 roler rockers -crane cam -1 3/4 long tube headers -offroad h pipe -ford motorsport plug wires -Pro Comp Ignition System and Distributor -Prothane Motor and Tranny Mounts -Manual Rack and Flaming River Steering Shaft -Line Lock -Tremec TKO Transmission -Spec Stage 3+ Clutch and Aluminum Flywheel -3.55 Gears -Poweretrax No Slip Locker -17" Bullitt Wheels -FMS Bullitt Calipers -New Paint -sub frame connectors -drive shaft loop -tubular upper and lower control arms -moser(sp) 31 spline axles -short throw shifter -K&N filter with extreme flow top I am picking up a 650 double pumper this weekend to replace the to big 750. here is a couple quick pix ![]() ![]()
-------------------- BRING IT TO THE TRACK AND PROVE IT
Jun 7 2009, 03:12 PM
Post
#2
Jun 8 2009, 07:20 AM
Post
#3
![]() Canada's Leader in Performance Product Availability ![]() ![]() ![]() Group: Admin Posts: 7933 Joined: 17-June 03 Member No.: 1 |
car looks great!
| Lo-Fi Version | Time is now: 9th September 2010 - 09:04 AM |
