Dirt Werx Performance Products
Motorcycle Accessories, Parts and Apparel
Welcome Guest ( Log In | Register )
Reply to this topicStart new topic
> RK TEK Online Q&A Thread
Spenc
post Dec 4 2006, 11:09 AM
Post #1
Canada's Leader in Performance Product Availability
Group: Admin
RK TEK
We welcome Kelsey Manning, owner of RK TEK for offering his expert advice to us here on the FROZEN THUNDER Snowmobile forums for our clients/members. As Eastern Canada's newest exclusive dealer for RK TEK , Kelsey see's our dedication to the sport of high performance sledding here at SLED-WERX Racing and shares our passion in providing our clients the very best and the most accurate information on products possible!
As you provide your questions below, we'll relay them to Kelsey and staff. Please be patient, as like us the guys at RK TEK are very busy drum'n up new GO FAST parts! Fire away your questions below!
For orders please call 1 613 925 4015
Go to the top of the page
+Quote Post
BRAAAPF7
post Dec 4 2006, 11:48 AM
Post #2
2KOOL Team Member - DUNES N' DIRT Moderator
Group: Members
I have RK Tek's first kit for the DD fix. Just wondering if there is more of a benefit to run the second kit with the helix over the first kit that i have?
+Quote Post
RK Tek
post Dec 5 2006, 12:09 AM
Post #3
Newbie
Group: Members
Yes, there are several advantages to the new kit.. We have incorporated a couple of changes that allow for cooler running clutching and less belt slip..
The new kit is also much easier to adjust and install.
Both kits work well. but the new kit , from testing, shows better overall performance
+Quote Post
zx 800
post Dec 5 2006, 08:46 AM
Post #4
Advanced Member
Group: Members
What is the differance in hp between your head vs the drop in kit. I know about the advantages of the single ring vs the dual. That the dual will not drop the hp like the single ring when heat soaked.
+Quote Post
RK Tek
post Dec 7 2006, 12:21 AM
Post #5
Newbie
Group: Members
The drop in kit includes the head and a custom base gasket..
Basically, it was developed to address the heat-soaking issues that is present with the stock piston.
We took it a step further and custom machined the piston to have a geometry that also added some serious power gains. So the drop in kit, due to its custom piston design, will increase power output over an engine that is just equipped with our head.
Kelsey
+Quote Post
adrenalator8
post Dec 7 2006, 04:38 PM
Post #6
ADVANCED DYNO
Group: Members
Kelsey:
what needles do you recommend for your 827 kit with porting.
I tryed the a needle shim and jetting the main up but couldn't keep it from scuffing the pistons after along pull across the lake "3000' "
I ran it with egts and the mids where really lean and I figured it was happening when I was letting off the throttle ,
Any ideas?
Thanks.
Advanced Dyno
(613) 925-5483
+Quote Post
Jeb
post Dec 10 2006, 04:42 PM
Post #7
Newbie
Group: Members
I read how you heads perfom by using less fuel and better com chamber design. How do you incorporate this with the 600 sdi when we cannot change fuel flow?
+Quote Post
Simon R
post Dec 15 2006, 09:38 AM
Post #8
Newbie
Group: Members
QUOTE (Jeb @ Dec 10 2006, 04:42 PM) *
Better specific engine output for same quantity of fuel injected = better economy (faster engine acceleration, broader torque band will result in less throttle usage to acheive the same results).
Good Luck,
T.D.
QUOTE (adrenalator8 @ Dec 7 2006, 04:38 PM) *
Kelsey:
Any ideas?
Thanks.
What thickness needle shim are you using ?
T.D.
Folks that say "money doesn't buy everything" are not shopping in the reight places!!!
+Quote Post
adrenalator8
post Dec 16 2006, 11:53 AM
Post #9
ADVANCED DYNO
Group: Members
I think it was a 0.030th shim,I had a really bad lean spot at around
7000rpm,i think these #'s are right it's been 3 years sence I ran it.
Cliff
Advanced Dyno
(613) 925-5483
+Quote Post
RK Tek
post Dec 16 2006, 02:41 PM
Post #10
Newbie
Group: Members
The less fuel is a result of a higher combustion efficiency of the head..
Whenever you make ANYTHING more efficient... you need LESS "X" to make the same "Y"
In the case of the head.. the Stock DOO head is very inefficient. meaning it converts a smallpercentage of F/A mix into energy that contributes to the power. So you always have excess raw unburnt fuel surrounding the head and piston and this acts as a cooling agent and keeps internal engine temps lower and aid in preventing engine failure.. What it also does is greatly lower engine power .
My head designs have a much higher combustion efficiency and have much less raw fuel left in the chamber after combustion.. So, since it is combusting a higher percentage of F/A that is "thrown" at it.. it requires less F/A to have complete combusion.
In the case of the SDI..the head by itself shows great power increases. this is just simply becsuse the chmaber design is much better than OEM.. If you want to acheive the max power from the head addition, an EFI controller is needed such that fuel can be pulled at WOT..
827 guy.. We ride Summits.. I run stock needle I suspect you have an aftermarket can or exhaust system that is causing the failure not a carb only problem.. We have found that the aftermarket cans and exhaust will cause a instant lean condition.
Also, check the base of your cylinder near the bust port.. These will warp and cause an air leak and instant burn down when letting off the throttle..
We have also redesigned the piston to allow for much better resistence to seizure.
We also have a custom timing curve that pulls timinginthe lower rpms that seems to help in that area also
Kelsey
+Quote Post
adrenalator8
post Dec 18 2006, 01:38 PM
Post #11
ADVANCED DYNO
Group: Members
Kealsy:
I ran the stock exhaust no can or pipe! This problem showed up in the first 40 miles so if it was the cylinder it was that way right out of the box??
I know that part of the first stick was from the nikki not adhearing well,when I pulled it apart there where flakes of nikki coming off that cylinder??
not sure why, could have been just bad bonding , but I had it redaone by Berniard in Quebec and the cylinder has lived fine after 2 more sticks.
I never had a problem with it out on the trail it was only on the lake.
It always stuck when getting out of the throttle.
as for the lean spot I just learned to drive around it ,
I was just wondering what you had come up with to help with the lean problem.
The kit made great power and was a blast to drive so later this winter I would like to put the cylinders on another block at do few tests on the dyno.
Cliff
Advanced Dyno
(613) 925-5483
+Quote Post
06MXZXRenegade80...
post Jan 3 2007, 10:09 AM
Post #12
HP Rules
Group: Members
Ok, ill bite. Your heads are available color anodized. whats the options? :)
Wrote off the 06 Gade X Mod. In the process of building another mod sled.
+Quote Post
Spenc
post Jan 3 2007, 10:55 AM
Post #13
Group: Admin
Just spoke with Kelsey for you Bro... GOLD is the color for the SKI DOO head ( GOLD ONLY at this time )
+Quote Post
06MXZXRenegade80...
post Jan 3 2007, 03:29 PM
Post #14
HP Rules
Group: Members
aww, no PINK?!?! LOL
Gold sounds good. I was just wondering what kind of funky creations would have been available but i dont want or need anything fancy!
Kelsey, you better not sell that kit! It will be coming my way shortly if all goes as planned!!! lol
T minus 11hours and counting till payday :)
+Quote Post
BIGBLOCKTODD
post Jan 29 2007, 09:31 AM
Post #15
Newbie
Group: Members
QUOTE (RK Tek @ Dec 5 2006, 01:09 AM) *
OK I HAVE A 2005 ZR 900 EFI IT HAS 85GRM DOLTENS 50-40 DOLTEN HELUX VFORCE REEDS 10.4 CLUTCH AND THE 06 BELT TORQUE ARM AT WHAT PERFORMANCE GAINS WILL I GET OUT OF THE RT TEK I MOSTLY TRAIL AND RACE 660 FEET IN THE SNOW
+Quote Post
Spenc
post Jan 31 2007, 07:12 PM
Post #16
Group: Admin
Kelsey will be along to answer questions, please be patient. These guys have offered their time for our clients, they are not on the pay-roll
+Quote Post
machz69
post Jul 18 2007, 10:19 AM
Post #17
Newbie
Group: Members
Hi there.... I have a 975 its 780 based... full porting..(race).. 670 rods..could get a one piece head that I could use my 809 top half (head)?. I dont want the head to cut so that it can only be run for 600'.. i will be running 2000'..
Thanks
+Quote Post
Garret 800HO
post Dec 4 2007, 10:49 AM
Post #18
Advanced Member
Group: Members
I was just wondering if Kelsey still answers questions here?
Got a question aboot my RK tek computer upgrade... I love it, but wanna know more about it.. Doesn't say a lot about it on his site. Any way, if you still do, I'll post later what I needs to know!
Thanks!
Garret
+Quote Post
EASY
post Nov 19 2009, 10:42 PM
Post #19
Newbie
Group: Members
I just bought an 05 rev 800/151 with the full RK drop in kit ( head, pistons, mpem upgrade) I ride in Golden and Revelstoke B.C.
Do I need to mix with race gas at that elevation??
how low can I go before I should consider mixing fuel??
Iam new to these kits so the more info the better, Even if it seems very basic to some of the guys who have been doing this for a while.
Thanks
(I have gone to the RK site, but that is not the info I was looking for unless I was looking in the wrong spot)
+Quote Post
adrenalator8
post Nov 23 2009, 09:37 PM
Post #20
ADVANCED DYNO
Group: Members
QUOTE (EASY @ Nov 19 2009, 10:42 PM) *
Thanks
HI.
That kit is mostly designed to increase the efficiency of the engine,I don't think there was a increase in Compression ratio, so I would be inclined to run 92 octane, race gas would be a over kill and you would lose power.
I ran his 827 kit at seal level and never needed anything over 92 and it was in the 165HP range.
Hope this helps
Cliff Yeatman
advanced dyno
Advanced Dyno
(613) 925-5483
+Quote Post
Lo-Fi Version Time is now: 9th September 2010 - 08:48 AM
