Dec 2 2006, 02:09 PM
Post
#1
![]() Canada's Leader in Performance Product Availability ![]() ![]() ![]() Group: Admin Posts: 7933 Joined: 17-June 03 Member No.: 1 |
Here are starting numbers D&D has come up with from field and dyno testing. These numbers should only be used as a starting point, as each sled is a little different, due to variations in fuel pressure, etc. These are for the latest D&D program, if you have an older box, with the 8300 range, add two numbers to the 8250 # for your 8300 #. As testing progresses, D&D will be updating numbers and adding applications.
2007 F1000 trail port/Y-pipe/single pipe, +2 timing/92 octane 3000 = -1 -1 -1 5000 = 6 4 0 6200 = 9 2 0 6500 = 9 5 0 6850 = 5 0 0 7250 = 5 5 5 7850 = 22 22 22 2007 F1000 Y /POWER SINGLE PIPE 3000= 00...00...00 5000= 00...00...00 6200= 04...00..-01 6500= 04...00..-02 6850= 00...00...00 7250= 00...00...00 7850= 15...15...15 2007 F1200 single pipe 3000 = 3 5 2 5000 = 7 5 5 6200 = 14 13 17 6500 = 18 16 16 6850 = 5 5 8 7250 = 14 14 20 7850 = 38 38 38 2007 F1000 trail port/Y-pipe/single pipe, no timing/92 octane 3000 = -1 -1 -1 5000 = 6 4 0 6200 = 4 2 0 6500 = 5 5 0 6850 = 0 0 0 7250 = 4 4 4 7850 = 18 18 18 2007 F1000 trail port/Y-pipe/single pipe, +2 timing/92 octane 3000 = -1 -1 -1 5000 = 6 4 0 6200 = 4 2 0 6500 = 5 5 0 6850 = 0 0 0 7250 = 5 5 5 7850 = 22 22 22 F7/M7 with monster twins, no timing. 3000 = 0 0 9 5000 = 0 0 12 6700 = 14 5 0 7300 = 14 0 0 7800 = 30 15 10 8250 = 30 25 18 8700 = 30 25 22 ------------------------------------------------------------------------ D&D/F8 with stock single (add two at 7800 for lite pipe, with D&D y-pipe) 3000 = 0 0 1 5000 = 0 1 1 6700 = 5 5 0 7300 = 5 5 0 7800 = 5 5 10 8250 = 5 5 15 8700 = 5 5 15 ------------------------------------------------------------------------- D&D/f8 with monster single 3000 = 0 0 4 5000 = -1 0 3 6700 = 0 -3 -5 7300 = 5 -2 -5 7800 = 15 5 5 8250 = 15 10 15 8700 = 15 10 35 ------------------------------------------------------------------------- D&D f8 with monster twins 3000 = 0 0 2 5000 = 2 2 5 6700 = 15 8 8 7300 = 15 8 14 7800 = 15 10 20 8250 = 20 15 24 8700 = 10 15 60 ------------------------------------------------------------------------ Stock D&D Ported F-8 Cyl's.05 ECU, Monster Twins,+3 timing key,fuel presure@ 42 psi 3000 = 0 0 2 5000 = 0 0 2 6700 = 10 7 0 7300 = 10 8 8 7800 = 20 24 24 8250 = 30 30 30 8700 = 20 20 60 ---------------------------------------------------------------------------- D&D/f9ss with monster single 3000 = 1 0 5 5000 = 0 1 5 6700 = 9 8 0 7300 = 12 9 0 7800 = 15 10 12 8250 = 20 15 24 8700 = 20 15 60 ------------------------------------------------------------------------ D&D/f9ss with monster twins 3000 = 2 1 5 5000 = 3 6 10 6700 = 9 8 3 7300 = 9 10 10 7800 = 0 12 18 8250 = 0 34 34 8700 = 0 60 60 ------------------------------------------------------------------------ stock f7 with monster single 3000 = 0 0 0 5000 = 0 0 0 6700 = 0 0 -5 7300 = 0 0 -5 7800 = 0 0 0 8250 = 0 0 +18 8700 = 0 0 +40 ----------------------------------------------------------------------------- D&D 757 with standard F-7 twin pipes 3000 = 0 0 4 5000 = 01 01 12 6700 = 14 10 04 7300 = 22 15 10 7800 = 30 15 15 8250 = 30 25 24 8700 = 30 25 30 67 Big Dogs/D&D Yellow,Green secondary,58/52 031 belt ------------------------------------------------------------------------------- D&D 1010 (ZR800 ECU) D&D monster single pipe,stock can,ethanol unpluged 3000 = 2 2 2 5000 = 4 5 4 6000 = 10 10 10 6700 = 10 10 6 tr = 01 7300 = 15 15 25 tr = 01 7800 = 25 30 45 tr = 01 8300 = 25 25 60 0627-035 belt/yellow spring,70.5 arms,D&D 57/52-5 helix,D&D gray secondary spring ----------------------------------------------------------------------------- ZR 2004(ZR 900 ecu) 1010 EFI D&D Twin Pipes 3000 =0....0....3 5000 =2....2....1 6700 =4....5....10 7300 -7....7....18 7800 =45...45...45 8250 =45...45...45 8700 =40...40...40 83 Big Dogs /Purple spring/50-40 helix D&D Tan ------------------------------------------------------------------------------- 2004/2005 zr 900 ecu/D&D 1010 kit /monster single 3000...0....0.....03 5000...1....4.....2 6700...6....4.....0 7300...9....7.....3 7800...25...25....28 8250...35...35....38 8700...40...40....40 D&D teal spring/77 BIG DOGS/Stock secondary 7900 RPM's ------------------------------------------------------------------------------- 2005/2006 F-6 D&D Monster Single Pipe 3000 = 0 0 0 5000 = 0 0 0 6700 = 0 -8 -13 7300 = 0 -2 -7 7800 = 0 0 0 8250 = 0 10 35 8700 = 0 10 40
Jan 2 2007, 11:17 PM
Post
#2
![]() FROZEN THUNDER 120+mph site Member Regional Site Trail Reporter ![]() ![]() ![]() Group: Members Posts: 800 Joined: 25-October 04 Member No.: 468 |
when do you think the 07 specs will come out??? for the f 10??
-------------------- When hell freezes over,, i will ride their too!!!
ALL THROTTLE.....Hmmm AND A LITTLE BOTTLE!! |
Jan 3 2007, 08:18 AM
Post
#3
The list above has been update this morning for you -
Hope this helps
Jan 3 2007, 10:48 PM
Post
#4
K <<<<<<<<< YOU <<<<<<<ROCK<<<<<<<<<!!!!!!!!!!!!!!!!!!!!!!!
THANKS!!!!!!!!!!!!!! -------------------- When hell freezes over,, i will ride their too!!!
Feb 3 2007, 11:12 AM
Post
#5
this is for a sled with only y-pipe and intake.. this is a trail set up.. for a richer mid,, and a richer pot side
3000..-1-1-1.0 5000 4.3.2.2 6200 5.6.5.2 6500 5.6.5.2. 6850 5.6.5.2. 7250..0.0.6.2 7850.0.0.6.2. again this is for y-pipe and intake.. leaner set up with over 400 miles on it!!! 3000..0.0.2 5000.0.0.2 6200.0.0.2 6500 .0.1.2 6850 0.1.2. 7250.2.2.2 7850.2.2.4 -------------------- When hell freezes over,, i will ride their too!!!
Feb 8 2007, 10:04 PM
Post
#6
wow is that new base line safe for the new programmed ecus???????
Feb 9 2007, 12:01 AM
Post
#7
taken off D&D's Tech board today
Jan 26 2008, 09:15 PM
Post
#8
08 F 1000 dd pipe,, y-pipe..
3000=00 00 00 5000=00 -3 -3 6200=00 -2 -10 6500=00 -4 -10 6850=-3 -3 -10 7250=05 05 05 7850=32 32 32 -------------------- When hell freezes over,, i will ride their too!!!
| Lo-Fi Version | Time is now: 9th September 2010 - 09:20 AM |
