Jump to content
STRAIGHTLINE Performance REV 600-800 Single Pipe Info
1 reply to this topic
#1 Guest_Spenc_*
  • Guests
Posted 30 October 2006 - 10:29 AM
Ski-Doo REV 800 Single Pipe. Bolt on 8-9 hp at 7800 on your 2004 Ski-doo 800 H.O. and 10+ at 7950 on your 800 H.O. Power-tek. Straightline's 800 pipe comes polished ceramic or black satin. The use of ceramic pipe does not require heat shields and has a great look. The black satin pipe will require the use of the heat shields for under hood temps and creates a great sleeper pipe. Pipe was designed to go into the stock muffler or SPI lightweight silencer.
Ski-Doo REV 600 Single Pipe. Straightline's 600 H.O. single pipe developed on the S.D.I. engine is a great for a 6+ hp gain at 7900-8000 rpm with a broader torque band and no fuel programming needed. The 600 H.O. single will work on the carbureted model too with similar gains. The 600 pipe comes polished ceramic or black satin. The use of ceramic pipe does not require heat shields and has a great look. The black satin pipe will require the use of the heat shields for under hood temps and creates a great sleeper pipe. Pipe was designed to go into the stock muffler or SPI lightweight silencer.
SITE SPECIAL On SPECIAL Only $375 CAD ceramic, $299 CAD Black satin.
Both Versions IN STOCK
New Mach Z 1000 Ceramic Single will be priced at $485 CAD
call to order 1 613 925 4015
  • Attached Image: post-1-1162222162.jpg
  • Attached Image: post-1-1162222175.jpg
#2 Guest_Spenc_*
  • Guests
Posted 12 December 2006 - 09:53 PM
Here's a fresh pic of the STRAIGHTLINE Performance REV 800 pipe.
By far the best welds we've seen to date for this application.
A great quality Dyno Proven pipe at an excellent price SPECIAL only $299 CAD
call to order 613 925 4015
  • Attached Image: post-1-1165978284.jpg
  • Attached Image: post-1-1165978307.jpg
