Dirt Werx Performance Products
Motorcycle Accessories, Parts and Apparel
Welcome Guest ( Log In | Register )
2 Pages V   1 2 >
Reply to this topicStart new topic
> NITROUS Q&A Thread, with guest host Mike Golightly from NX
Spenc
post Dec 9 2005, 02:25 PM
Post #1
Canada's Leader in Performance Product Availability
Group: Admin
NITROUS Q & A Thread
Please ask your questions below as we have an expert on hand who's been in the business of nitrous POWERSPORTS since 1968. Hired by Nitrous Express, Mike Golightly has offered our forums members insite and directions for all sled applications.
As you have your questions, we'll relay them to Mike and then back to you. Please be patient, as Mike's a busy dude! Hope this helps. Interest in this HP modification is becoming more popular so we felt it was appropriate to have an industry expert on hand to help our clients. We thank Mike for his offer in edjucating our readers/clients .
Attached Image Attached Image Attached Image
Go to the top of the page
+Quote Post
adrenalator8
post Dec 9 2005, 07:21 PM
Post #2
ADVANCED DYNO
Group: Members
I have a 05 Mach-z and have played with the idea of putting some NOS on it .
THe thing that I would like to know is that Boondockers makes a kit that comes with a add on computer that helps deal with the issues of nos
ie timing, fuel and control of the solnoids.
The NX system is a stand alone system ie" no extra computer"
Why is it better then the other and what are the + and - of a wet to a dry.
Thanks in advance.
"Adrenaline junkie"
Advanced Dyno
(613) 925-5483
+Quote Post
Spenc
post Dec 9 2005, 09:10 PM
Post #3
Group: Admin
Reply from Mike Golightly - NX POWERSPORTS
We have found that as long as you control both the fuel and the nitrous
pressures and volumes there is no need to to alter the standard engine
tune-up. This not only makes the system NOT model specific which keep the cost down, it also allows the Nitrous to work correctly and always add the amount of power you have tuned it for.. If you do not keep the Nitrous
bottle pressure between 850 psi and 1050psi the Nitrous will not perform to its maximum no matter what you do the fuel and or timing. And as far as ignition goes we have found that aslong as your are not adding over 50 hp you do not need to worry about ignition timing.
Nitrous system are best if they are wet simply because most factory EFI
systems can not handle the INSTANT need for fuel, and most factory EFI fuel pumps dont really have the capacity to handle the fuel demands at all and soon fail completely, by using aWET nitrous kit you have a stand alone fuel system that is capable of handling all the fuel requirements for the Nitrous with out overworking the stock pump. A wet system also atomizes the fuel FINER than EFI and makes a much better combution
Again, Mike has been KooL enough to provide his experience and knowledge to our forum members, so please keep in mind we're only transfering information here for you.
+Quote Post
firecat
post Dec 10 2005, 05:18 PM
Post #4
FROZEN THUNDER 120+mph site Member Regional Site Trail Reporter
Group: Members
hay spence do you have a ZEX spray kit for my rx1,,, i have it set up for it now ,, im gona start with a 40-50 nozzel thanks!! also my fusion H.O is all most ready too.... c ya
When hell freezes over,, i will ride their too!!!
ALL THROTTLE.....Hmmm AND A LITTLE BOTTLE!!
+Quote Post
Spenc
post Dec 10 2005, 09:24 PM
Post #5
Group: Admin
PM me Bro.... we'll look after ya
+Quote Post
adrenalator8
post Dec 10 2005, 10:28 PM
Post #6
ADVANCED DYNO
Group: Members
Ok so far so good!
so if you have a constant temp in the bottle then the pressue will be right,between 850-1050.
So this tells me that if the pressure/temp is low then it's just the nitrous thats lean , not the fuel so there should be no engine damage if a problem with that side happens?
Am I getting this right so far??
So another couple of Q for you .
Lets say a 50hp shot on my Mach-z 1000 how long could you hold the nitrous on before damage accures, that is as long as there are no issues to start with ie it's already a good runner?
I have heard that the nitous gives the engine a sort of cooling effect is this true ??
And that the ratio for nitrous to fuel is about 1-2??
I will think of more later but this is a good start.
Thanks again.
Advanced Dyno
(613) 925-5483
+Quote Post
Spenc
post Dec 12 2005, 01:31 PM
Post #7
Group: Admin
You never go LEAN on nitrous, if the bottle pressure is it will make the
mixture RICH.
You could stay on the Nitrous untill you either run out of Nitrous (as long
as you can keep the pressure up) or you run out of room.
Yes Nitrous is the BEST intercooler ever, this one of the reasons we use
Nitrous instead of Oxygen.
The best air/fuel raio on normal motor is about 14.5 to 1
and on Nitrous it is about 12.7 to 1
+Quote Post
Spenc
post Dec 20 2005, 10:23 PM
Post #8
Group: Admin
Here's some information on how much nitrous it takes for duration of time used.
The amount of run time is
base on the amount of nitrous on board. It takes 2.5 lbs of nitrous to make
50 hp for a minute ( or 1.25 lbs of nitrous will make 50 hp for 30 seconds
or make 25 hp for a minute)
+Quote Post
firecat
post Dec 28 2005, 09:54 PM
Post #9
Group: Members
damm that means i need a 6 pack of bottles!!!
+Quote Post
firecat
post Jan 23 2006, 07:34 PM
Post #10
Group: Members
so after i drained my first bottle of nos,,,, the filling station in ottawa brunos performance says to freeze the bottle before filling ,,,,is this better,,,, mabey to condence the nos when filling???? ps very nice kit from NX EXPRESS way 2 kool
+Quote Post
Spenc
post Jan 25 2006, 01:07 PM
Post #11
Group: Admin
Cooling or freezing the bottle prior to refilling is not needed unless they are not using a refill pump.
+Quote Post
firecat
post Jan 30 2006, 07:20 PM
Post #12
Group: Members
also as per my pic above the nos line is pointed forward,,, and the neck of the bottle,,,, and was thinking,,,, mabey i am hindering flow,,, and mabey even a lot,,, whats your take??? but i need to keep the bottle mount where it is,, but mabey reversed??? or something? THANKS
+Quote Post
Spenc
post Jan 31 2006, 08:50 AM
Post #13
Group: Admin
That bottle mount is fine as long as the hose is connection on the bottle is
pointed to the rear
You might want to consider a bottle heater (#15938) to help maintain the
correct pressure which will make better power
+Quote Post
firecat
post Feb 10 2006, 05:33 PM
Post #14
Group: Members
thanks you guys @ NX rock
+Quote Post
rev1011
post Mar 23 2006, 08:28 PM
Post #15
TRIPLE REV
Group: Members
What would be a safe compression ratio/ cranking compression for nitros on a 1/4 mile asphalt motor? Allready have the kit but don't want to use it unless it's feesable on my motor
+Quote Post
Spenc
post Mar 23 2006, 10:11 PM
Post #16
Group: Admin
Max recommended COLD CRANKING compression should not exceed 180lbs .
Thanks Mike
+Quote Post
rev1011
post Mar 24 2006, 07:52 AM
Post #17
TRIPLE REV
Group: Members
So at 180 lbs cold crank what would be the max hp shot of nitrous that would be safe to use? THNX
+Quote Post
Spenc
post Mar 24 2006, 01:10 PM
Post #18
Group: Admin
tough to answer, lots of variables, but 65 to 70 hp per cylinder should be
near the max
+Quote Post
rev1011
post Mar 24 2006, 09:12 PM
Post #19
TRIPLE REV
Group: Members
To get a little more into this, I am running a 1006 motor at 9800+ rpm and am looking at putting somewhere around a 25hp per cylinder shot at it but I am also hoping not to have a grenade in my hands. Running an msd so timing is easy to change. Any thoughts or advice is greatly appreciated.
JOHN
+Quote Post
Spenc
post Mar 27 2006, 12:27 PM
Post #20
Group: Admin
25 hp would usually need nothing other a good tune up in the first place and
the the use of good fuel (105+ octane or slightly higher)
+Quote Post
mad man racer
post Oct 3 2006, 10:24 PM
Post #21
Newbie
Group: Members
? for the nos guy. I have an 05 rev 600 carb. I bought a used boondocker system with a 40 hp shot.
1. can i run a 40 hp shot on premium fuel. or do i need to go down to a 30 hp shot. Race fuel not very convenient for me.(boon docker said ill be fine with premium with 40 hp shot.
2. How long can i hold the button down safely.
3. If i hit the button at half throttle throttle is it going to hurt any thing.
4. do i need to remove the foam in the air box next to the nos manifolds.
5. Do i need to go to a higher number plug? (br9ecs to br10ecs)
thanks for all your help.
+Quote Post
Spenc
post Oct 4 2006, 03:00 PM
Post #22
Group: Admin
1 If the engine has stock compression premiun fuel is ok
2 Bottle pressure is your main limiting factor, if the pressure drops too low then the maotor goes very rich and could foul plugs
3 Nitrous should only be used at WIDE OPEN, period!
4 I dont know about that, we install our nozzles on the engine side of the carbs
5 The 9 is perfect
Thanks Mike
+Quote Post
mad man racer
post Oct 5 2006, 09:32 PM
Post #23
Newbie
Group: Members
nother ? for you.
on a boon docker system when using the barometer to set up pressureon a 05 rev. do i need to have the sled wide open for set up with air box closed to motor?
i was messing with it tonight and i was just letting it idle with the air box door open. hitting the button for about 2 seconds. i could not get real consistent pressure. It would bounce down real far. Then settle for a little bit and then just drop. it would not hold its pressure. What am i doing wrong? what do i need to do?
Thank u very much for your help.
+Quote Post
Spenc
post Oct 6 2006, 04:19 PM
Post #24
Group: Admin
I am sorry but I am not familiar with that type of set up, NX systems dont use a controller based on barometric pressure.
+Quote Post
HeavyHitter
post Jan 4 2007, 09:35 AM
Post #25
Member
Group: Members
Question on compression and timing. If you are running 190-200lbs compression would there be extreme cylinder pressures with a chance to cause damages or could you run a lower HP shot of Nos and also should the timing be put back to stock. This is a strictly drag sled running C14 but I also see VP fuel has a C16 when running NOS would this fuel allow me to keep higher compression and timing? Thanks for your time.
+Quote Post
Spenc
post Jan 5 2007, 04:14 PM
Post #26
Group: Admin
That is right at my suggested maximun compression number and C-14is the correct fuel. You should be OK, just constantly check the plugs after each run , checking closely for small shiny spots (aluminum), that means too much timing, retard about 2 degress or .5mm
+Quote Post
HeavyHitter
post Jan 5 2007, 10:59 PM
Post #27
Member
Group: Members
Thank you very much for the info appreciate the responce Glenn 080402cool_prv.gif
+Quote Post
Spenc
post Jan 5 2007, 11:11 PM
Post #28
Group: Admin
ah.......... it's MIKE GOLIGHTLY that you're thanking amigo ( heavy on the 'amigo' )
+Quote Post
rev1011
post Jan 15 2007, 12:38 PM
Post #29
TRIPLE REV
Group: Members
What jet sizes would you recommend for a 65hp per cylinder shot of n2o? running 900+psi bottle pressure and at 8psi fuel pressure.
+Quote Post
Spenc
post Jan 16 2007, 03:16 PM
Post #30
Group: Admin
use a #32 N2O and #24 fuel
+Quote Post
2 Pages V   1 2 >
Lo-Fi Version Time is now: 9th September 2010 - 09:23 AM
