putting in a rocket key/ time advance key
13 replies to this topic
#1 Guest_Snoix_*
  • Guests
Posted 13 February 2005 - 08:48 PM
1: Unplug the spark plug wire from the motor (for safety). Remove the fan cover from the motor. There are 3 hex bolts holding down the fan cover, and one bolt holding down the fan shroud near the spark plug.
  • Attached Image: post-73-1108345748.jpg
#2 Guest_Snoix_*
  • Guests
Posted 13 February 2005 - 08:50 PM
2.Remove the flywheel. To remove the flywheel you need a 8mm socket and wrench. i used my hex tool to hold the flywheel stationary so i can remove the flywheel bolt. Be careful, it is possible to snap a fan blade off (do this at your own risk!)
  • Attached Image: post-73-1108345825.jpg
#3 Guest_Snoix_*
  • Guests
Posted 13 February 2005 - 08:51 PM
3: Remove the Flywheel. Use 2 (long) M6 Threaded bolts and turning them in until they pry the flywheel off. These bolts are not supplied, so i recommend going to a hardware store to get the appropriate bolts.
(! I noticed that where the 8mm bolt is, there was some epoxy or some sort of glue there. it may be hard to remove the flywheel so be careful!)
#4 Guest_Snoix_*
  • Guests
Posted 13 February 2005 - 08:52 PM
4: Remove the stock key. I used a small pick with a rubber mallet to remove the stock key.
#5 Guest_Snoix_*
  • Guests
Posted 13 February 2005 - 08:53 PM
5.Install the new advanced key in place of the stock key. notice the offset of the new key is towards the right
#6 Guest_Snoix_*
  • Guests
Posted 13 February 2005 - 08:54 PM
6. Put the fly wheel back together
#7 Guest_Spenc_*
  • Guests
Posted 13 February 2005 - 09:00 PM
GREAT POST.....
#8 Guest_Snoix_*
  • Guests
Posted 13 February 2005 - 10:21 PM
thanks?
if your serious
#9 Guest_Spenc_*
  • Guests
Posted 13 February 2005 - 11:04 PM
I'm always serious It's a great informative post, with very clear, easy to follow steps. The guys will appreciate it.
Thanks again
#10 Guest_Snoix_*
  • Guests
Posted 13 February 2005 - 11:27 PM
if theres anything else u would like me to do for how two's just tell me via PM
#11 Erwan
    2KOOL Team Member
  • 531 posts
Posted 14 February 2005 - 12:35 AM
Just want to give credit where its due, but thanks for posting the info!
http://moto.staticlabs.org/tech/timing/index.html
Great addition
E
#12 Guest_Snoix_*
  • Guests
Posted 14 February 2005 - 08:03 AM
LOL i was taking pics myself and writing it cause i put my rocket key in that powersports plus gave me and
i told my friend what i was doing and he gave me a link
im like pssh
hell ya ill just use that..
but i would of done it myself and i will post the pics:P
and theres a much easyer way to pull off the flywheel
all you have to do is.
bah ill post pics ill put them on the compy
but THANKS ERWAN:P
#13 Guest_Snoix_*
  • Guests
Posted 04 June 2005 - 09:32 PM
just get 2 strong screw drivers on each side of the flywheel and pry it up as hard as u can and it will pop up and off.
and if theres 2 ppl there dol the prying then get someone to litely hit the center with a hammer. will come up easyer. i did it myself today
#14 1.5dx2go
    Newbie
  • 2 posts
Posted 22 January 2006 - 10:58 PM
You can also get 2 large screws with the same thread pitch as the 2 holes in the flywheel and slowly and evenly screw the two screws in until it pops and then just take it off. Thats how I do it. Works pretty good.
