STREETBIKE Rubber Availability
11 replies to this topic
#1 Guest_Spenc_*
  • Guests
Posted 13 April 2005 - 10:27 PM
and keep an eye on our 2KOOL BIKE-WERX division for Online Specials!
http://www.2koolperformance.ca/bike_werx/
  • Attached Image: post-37-1113449235.jpg
  • Attached Image: post-1-1149961433.jpg
#2 Guest_Spenc_*
  • Guests
Posted 13 April 2005 - 10:32 PM
DUNLOP
Dunlop D208 ZR
The D208 ZR's next-generation cosecant groove tread pattern yields a consistent ratio of rubber-to-groove area at all lean angles from vertical to maximum lean.
Speed Rating: ZR
1 613 925 4015
sales@2koolperformance.ca
  • Attached Image: post-37-1113449536.jpg
#3 Guest_Spenc_*
  • Guests
Posted 13 April 2005 - 10:38 PM
MICHELIN
Michelin Pilot Road
Sets new standards for wet grip and cold-weather performance, with impressive durability as well, thanks to the silica rubber mix. Compounds for both front and rear have been optimized to promote balanced wear on both wheels.
Speed Rating: ZR
1 613 925 4015
  • Attached Image: post-37-1113449928.jpg
#4 Guest_Spenc_*
  • Guests
Posted 13 April 2005 - 10:41 PM
Michelin Pilot Power
Rubber mix remains soft even at lower temperatures, providing excellent grip throughout your ride.
Speed Rating ZR
1 613 925 4015
  • Attached Image: post-37-1113450074.jpg
#5 Guest_Spenc_*
  • Guests
Posted 13 April 2005 - 10:43 PM
Michelin Pilot Sport HPX
Engineered with a particular emphasis on high-speed stability, The rear Pilot Sport HPX has been certified under stringent European requirements.
Speed Rating: ZR
1 613 925 4015
  • Attached Image: post-37-1113450187.jpg
#6 Guest_Spenc_*
  • Guests
Posted 13 April 2005 - 10:45 PM
BRIDGESTONE
Bridgestone BT-012SS
3D C.T.D.M. (Comprehensive Tire Design Method) is advanced tire design technology that enables dynamic, three-dimensional simulations of tire performance to find optimum desing at all lean angles.
speed rating ZR
1 613 925 4015
  • Attached Image: post-37-1113450347.jpg
#7 Guest_Spenc_*
  • Guests
Posted 13 April 2005 - 10:47 PM
Bridgestone BT-014
Innovative tread design to improve traction, shock absorption, wet performance and noise reduction. NEW Ultra high performance radial designed for the aggressive street rider.
speed rating ZR
1 613 925 4015
  • Attached Image: post-37-1113450436.jpg
#8 Guest_Spenc_*
  • Guests
Posted 13 April 2005 - 10:49 PM
Bridgestone BT-020
Silica compound provides improved and exceptional grip level on both dry and wet surfaces without sacrificing high speed durability
speed rating ZR
1 613 925 4015
  • Attached Image: post-37-1113450549.jpg
#9 Guest_Spenc_*
  • Guests
Posted 13 April 2005 - 10:51 PM
MAXXIS
Maxxis Supermaxx M6029
A revolutionary radial constructed carcass uses mono-spiral wound Kevlar constructed carcass belts to provide tire uniformity at high speeds.
Speed Rating: Z
1 613 925 4015
  • Attached Image: post-37-1113450740.jpg
#10 Guest_Spenc_*
  • Guests
Posted 13 April 2005 - 10:55 PM
Continental
Conti Force-Sport Radial
Light and responsive. Very fast warm-up times.
Speed Rating: ZR
1 613 925 4015
  • Attached Image: post-37-1113450927.jpg
#11 Guest_Spenc_*
  • Guests
Posted 13 April 2005 - 10:57 PM
Conti Force MAX-HP
Because it has greater high speed stability than the standard Conti Force the MAX is more suitable for sports bikes over 1000cc.
Speed Rating: ZR
1 613 925 4015
  • Attached Image: post-37-1113451059.jpg
#12 Guest_Spenc_*
  • Guests
Posted 13 April 2005 - 11:00 PM
Conti Force Road Attack
Exclusive 0 degree High impact steel belt construction delivers the highest levels of grip, high speed stability, control and comfort.
Speed Rating: Z
1 613 925 4015
  • Attached Image: post-37-1113451247.jpg
